Foundation For A New Tomorrow
Published © CC BY-NC-SA
Automatic Climate-Controlled Organic Garden
Imagine growing any kind of food or crop at home or commercially, year round, in a self-contained system. We could feed the hungry!
IntermediateShowcase (no instructions)24 hours1,068
Things used in this project
Hardware components
Intel Edison
Intel Edison
×1
Grove starter kit plus for Intel Edison
Seeed Grove starter kit plus for Intel Edison
×1
Electric Drill (Generic)
Circular Saw (Generic)
Story
Read more
Code
Automatic Climate-Controlled Garden
Arduino
 * Automatic Climate-Controlled Organic Garden Control Software
 * Foundation For A New Tomorrow
 * Code By: J. Amin and A. Scott
 * Self-contained, climate-controlled, automated garden
 * that maintains and regulates lighting, watering, and
 * temperature via relays, based on constant feedback from
 * moisture, light, water,and temperature sensors.
   Sensor Initializations
//#include<Time.h>
//LCD Initialization
#include <Wire.h>
#include "rgb_lcd.h"
rgb_lcd lcd;
#include <Digital_Light_TSL2561.h> //Digital Light Sensor
#include <math.h>
//All Sensor Init
#define TEMP A3
#define MOISTURE A0
#define UV A1
#define DRY_REED 2
//#define LIGHT 6
#define WATER 3
#define RELAY 5
#define RELAY2 8
void pins(){
  pinMode(TEMP, INPUT);
  pinMode(MOISTURE, INPUT);
  //pinMode(UV, INPUT);
  pinMode(DRY_REED, OUTPUT);
  //pinMode(LIGHT, INPUT);
  pinMode(WATER, INPUT);
  pinMode(RELAY, OUTPUT);
  pinMode(RELAY2, OUTPUT);
//Global values
bool lights_on=true;\
unsigned long elapsed_time=43200000;
int m=1;
unsigned long previous=0;
int a;
float temperature;
int B=3975;                  //B value of the thermistor
float resistance;
 // Initialize all pins
 pins();
 TSL2561.init();
  //Initialize LCD
 //LCD_setup();
// set up the LCD's number of columns and rows:
    lcd.begin(16, 2);
    // initialize the serial communications:
    Serial.begin(9600);
    //time1=millis();
 lights();    //RELAY
 water_check();
 moisture();  //DRY_REED RELAY -- water pump
 heat();     //RELAY2
 disp();
//Functions for All Sensors
//Check if water tank is empty
void lights(){
   //Auto-toggle the lights for 12h intervals
   unsigned long current=millis();
  if(lights_on=true)
   digitalWrite(RELAY, HIGH); //lights on
  else{digitalWrite(RELAY,LOW);} //lights off
 if ((unsigned long)(current - previous) >= elapsed_time) {
    if(lights_on=true)
      lights_on=false;
      //digitalWrite(RELAY, LOW); //turn off lights
      //Update timer
      previous=current;
    else if(lights_on=false)
      lights_on=true;
      //digitalWrite(RELAY,HIGH);
      //Update timer
      previous=current;
void water_check(){
  //Check water tank
  if(digitalRead(WATER)==1)
    lcd.setCursor(0,0);
    lcd.print("Water: Empty!");
    lcd.setRGB(100,0,0);
    delay(2000);
    //lcd.clear();
    //lcd.setRGB(50,50,50);
void disp(){
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("Temp: ");
 a=analogRead(TEMP);
 resistance=(float)(1023-a)*10000/a; //get the resistance of the sensor;
 temperature=1/(log(resistance/10000)/B+1/298.15)-273.15;//convert to temperature via datasheet&nbsp;;
 lcd.print(temperature);
 lcd.print( "C");
 //lcd.print(analogRead(Temp));
 lcd.setCursor(0,1);
 lcd.print("Lights:");
 if(lights_on==true){lcd.print(" On");}
 else if(lights_on==false){lcd.print(" Off");}
 delay(2000);
 lcd.clear();
  void light_diag(){
  //Check Light Sensor (Box#1 lights)
  if((TSL2561.readVisibleLux()==0) && (lights_on=true))
    lcd.setCursor(0,1);
    lcd.setRGB(200,0,0);
    lcd.print("Light Bulb: Out");
    delay(2000);
    lcd.clear();
void moisture(){
  int humid;
  humid=analogRead(A0);
  if(humid<40){
    digitalWrite(DRY_REED,HIGH);
  else
    {digitalWrite(DRY_REED, LOW);}
void heat(){
  if(temperature<25.00)
    digitalWrite(RELAY2,HIGH);
  else{digitalWrite(RELAY2,LOW);}
Credits
1 project • 2 followers
Comments
Add projectSign up / Login
