Elmin Delibašić
Published © GPL3+
GreenHouse Monitoring System
Android application monitoring system for GreenHouse, several sensors for reading data and send to application.
IntermediateFull instructions provided10 hours11,239
Things used in this project
Hardware components
NodeMCU ESP8266 Breakout Board
×1
DHT11 Temperature & Humidity Sensor (3 pins)
×1
SparkFun Soil Moisture Sensor (with Screw Terminals)
×1
Grove - Gas Sensor(MQ2)
Seeed Grove - Gas Sensor(MQ2)
×1
Li-Ion Battery 1000mAh
×1
Arduino Nano R3
Arduino Nano R3
×1
Arduino IDE
Arduino IDE
Android Studio
Android Studio
Firebase
Google Firebase
Story
Read more
Schematics
Scheme
Code
nodemcu.ino
Arduino
#include <PubSubClient.h>
#include <FirebaseArduino.h>
#include <ESP8266WiFi.h>
#include <ArduinoJson.h>
#include <dhtnew.h>
#define FIREBASE_HOST "firebase_link"
#define FIREBASE_AUTH "firebase_secret"
#define WIFI_SSID "wifi_name"
#define WIFI_PASSWORD "wifi_password"
int soilPin = 5, airPin = A0, dhtPin = 16;
DHTNEW dhtsensor(dhtPin);
  //Serial Begin at 9600 Baud
  pinMode(soilPin, INPUT);
  pinMode(airPin, INPUT);
  Serial.begin(9600);
     WiFi.begin (WIFI_SSID, WIFI_PASSWORD);
        while (WiFi.status() != WL_CONNECTED) {
           delay(500);
            Serial.print(".");
          Serial.println ("");
          Serial.println ("WiFi Connected!");
          Serial.println(WiFi.localIP());
     Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
int soilData = digitalRead(soilPin);
Firebase.setInt("soilData", soilData);
int airData = analogRead(airPin);
Firebase.setInt("airData", airData);
dhtsensor.read();
float t = dhtsensor.temperature;
float h = dhtsensor.humidity;
Firebase.setFloat("t", t);
Firebase.setFloat("h", h);
delay(2000);
MainActivity.java
Java
package com.example.elmin.plastenik;
import android.graphics.Color;
import android.support.annotation.NonNull;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.widget.Button;
import android.widget.TextView;
import com.google.firebase.database.DataSnapshot;
import com.google.firebase.database.DatabaseError;
import com.google.firebase.database.DatabaseReference;
import com.google.firebase.database.FirebaseDatabase;
import com.google.firebase.database.ValueEventListener;
public class MainActivity extends AppCompatActivity {
    DatabaseReference dref;
    TextView text_temperature, text_humidity, text_airquality, text_soilmoisture;
    String temp, hum, air, soilmoisture;
    int col1 = Color.parseColor("#b32d00"), col2 = Color.parseColor("#000000");
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        text_temperature = (TextView) findViewById(R.id.textTemp);
        text_airquality = (TextView) findViewById(R.id.textAir);
        text_humidity = (TextView) findViewById(R.id.textHum);
        text_soilmoisture = (TextView) findViewById(R.id.textSoil);
        dref = FirebaseDatabase.getInstance().getReference();
        dref.addValueEventListener(new ValueEventListener() {
            @Override
            public void onDataChange(@NonNull DataSnapshot dataSnapshot) {
                temp = dataSnapshot.child("t").getValue().toString();
                text_temperature.setText(temp + "C");
            @Override
            public void onCancelled(@NonNull DatabaseError databaseError) {
            @Override
                hum = dataSnapshot.child("h").getValue().toString();
                text_humidity.setText(hum + "%");
            @Override
            @Override
                air = dataSnapshot.child("airData").getValue().toString();
                text_airquality.setText(air);
            @Override
            @Override
                soilmoisture = dataSnapshot.child("soilData").getValue().toString();
                int soilData = Integer.parseInt(soilmoisture);
                if (soilData == 0) {
                    text_soilmoisture.setText("No watering required.");
                    text_soilmoisture.setTextColor(col2);
             else {
                    text_soilmoisture.setText("Watering required!");
                    text_soilmoisture.setTextColor(col1);
            @Override
activity_main.xml
XML
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:app="http://schemas.android.com/apk/res-auto"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    tools:context=".MainActivity">
  <RelativeLayout
      android:layout_height="75dp"
      android:layout_marginTop="10dp"
      android:layout_marginLeft="20dp"
      android:layout_marginRight="20dp"
      android:background="#f3f4ee">
      <TextView
          android:layout_width="150dp"
          android:layout_height="40dp"
          android:layout_marginTop="15dp"
          android:layout_marginLeft="50dp"
          android:textSize="16dp"
          android:gravity="center"
          android:text="Temperature"
          android:textColor="#000000"
          android:alpha="0.8"/>
      <ImageView
          android:layout_width="40dp"
          android:layout_marginLeft="5dp"
          android:src="@drawable/temperature"
        <TextView
            android:id="@+id/textTemp"
            android:layout_height="50dp"
            android:layout_marginLeft="200dp"
            android:textSize="40dp"
            android:text="N/A"
            android:alpha="0.8"
  </RelativeLayout>
    <RelativeLayout
        android:layout_marginTop="95dp"
        <TextView
            android:text="Humidity"
        <ImageView
            android:layout_marginLeft="10dp"
            android:src="@drawable/humidity"
        <TextView
            android:id="@+id/textHum"
            android:text="N/A"
            android:alpha="0.8"
    </RelativeLayout>
    <RelativeLayout
        android:layout_height="120dp"
        android:layout_marginTop="180dp"
        android:layout_marginBottom="20dp"
        <ImageView
            android:layout_width="80dp"
            android:layout_height="80dp"
            android:layout_marginTop="25dp"
            android:src="@drawable/soil"
        <TextView
            android:id="@+id/textSoil"
            android:layout_width="200dp"
            android:layout_marginBottom="10dp"
            android:layout_marginLeft="130dp"
            android:textAlignment="center"
            android:textSize="25dp"
            android:text="N/A"
            android:alpha="0.8"
    </RelativeLayout>
    <RelativeLayout
        android:layout_height="180dp"
        android:layout_marginTop="310dp"
        <TextView
            android:layout_width="90dp"
            android:layout_marginTop="30dp"
            android:layout_marginLeft="55dp"
            android:text="Air Quality"
        <ImageView
            android:src="@drawable/airquality"
        <TextView
            android:id="@+id/textAir"
            android:layout_marginTop="90dp"
            android:text="N/A"
        <ImageView
            android:layout_marginLeft="150dp"
            android:src="@drawable/kvalitetazraka"/>
    </RelativeLayout>
</RelativeLayout>
Credits
Elmin Delibašić
Elmin Delibašić
7 projects • 42 followers
Bachelor of Electrical Engineering (Department of Telecommunications)
Comments
Add projectSign up / Login
