Iasonas Christoulakis
Published © GPL3+
Set up a 5V Relay on the Arduino
One of the most useful things you can do with an Arduino is control higher voltage (120-240V) devices like fans, lights, heaters and others.
IntermediateWork in progress8 hours3
Things used in this project
Hardware components
Arduino UNO & Genuino UNO
×1
Grove - 2-Channel SPDT Relay
Seeed Grove - 2-Channel SPDT Relay
×1
Jumper wires (generic)
×1
Single Turn Potentiometer- 10k ohms
×1
Resistor 10k ohm
Resistor 10k ohm
×1
Breadboard (generic)
×1
Arduino IDE
Arduino IDE
Fritzing
Wire Cutter / Stripper, 5.25 " Overall Length
Story
Read more
Schematics
Schematics
Code
CODE
C/C++
#include <math.h>
int pinOut = 10;
double Thermistor(int RawADC) {
 double Temp;
 Temp = log(10000.0*((1024.0/RawADC-1)));
 Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp );
 Temp = Temp - 273.15;
 Temp = (Temp * 9.0)/ 5.0 + 32.0;
 return Temp;
  Serial.begin(9600);
  pinMode(10, OUTPUT);
  int val;
  double temp;
  val=analogRead(0);
  temp=Thermistor(val);
  Serial.print("Temperature = ");
  Serial.print(temp);
  Serial.println(" F");
  if (temp >= 150){
    digitalWrite(pinOut, LOW);
  else {
    digitalWrite(pinOut, HIGH);
  delay(500);
Credits
8 projects • 4 followers
Comments
Add projectSign up / Login
