Parker SchmidTravis DixonThomas Cody
Published
Home Security Motion Sensor
Home security alert system which remotely detects motion at your door and notifies you when someone enters your home!
BeginnerWork in progress6 hours69
Things used in this project
Hardware components
Argon
Particle Argon
×3
Grove - PIR Motion Sensor
Seeed Grove - PIR Motion Sensor
×1
High Brightness LED, White
×3
Jumper wires (generic)
×7
Male/Female Jumper Wires
×3
Solderless Breadboard Half Size
×3
USB-A to Micro-USB Cable
Wall adaptors included.
×3
Google Sheets
Google Sheets
Maker service
IFTTT Maker service
Particle Build Web IDE
Story
Read more
Schematics
Motion Sensor Module
Indicator Module
PIR Motion Sensor
Indicator 1
Indicator 2
Code
Argon LED Indicator
C/C++
This is the code used to allow the Argon to use an LED to indicate when the motion detector has detected motion.
//LED ARGON 1 (TRAVIS)
int led = D7;
int state = 0;
int Good_Recieve = 1;
pinMode(led, OUTPUT);
//digitalWrite(led, LOW);
Particle.subscribe("Motion_alert", myHandler, "e00fce682e9728551f3c44ac");
void myHandler(const char *Motion_Alert, const char *myHandler)
Particle.publish("Recieved", String(Good_Recieve));
  digitalWrite(led, HIGH);
Motion Detector
C/C++
This is the code that takes a signal from the motion detector and causes the Argon to send a signal to the LED indicator to blink,
//Motion sensor
int inputPin = D0;
int ledPin = D7;
int pirState = LOW;
int val = 0;
int myHandler =1;
int led = D7;
int calibrateTime = 5000;
  pinMode( ledPin, OUTPUT );
  pinMode(inputPin, INPUT);
  Particle.subscribe("Recieved", Good_Recieve, "E00FCE685C596CC5CD3975CB");
  Particle.subscribe("Recieved", Good_Recieve, "e00fce68144a467e5d29be7a");
void Good_Recieve(const char *event, const char *data)
  if ( calibrated() )
    readTheSensor();
    reportTheData();
void readTheSensor() {
  val = digitalRead(inputPin);
bool calibrated() {
  return millis() - calibrateTime > 0;
void reportTheData() {
  if (val == HIGH) {
   myHandler= myHandler;
   Particle.publish("Motion_alert", String(myHandler));
   delay(10000);
   else if (pirState == LOW) {
     myHandler = 0;
void setLED( int state )
  digitalWrite( ledPin, state );
Credits
Parker Schmid
Parker Schmid
1 project • 0 followers
Travis Dixon
Travis Dixon
Thomas Cody
Thomas Cody
Comments
Add projectSign up / Login
