kkim20
Published
Green Box: Fully Automated at Home Hydroponics System
The Green Box is an automated hydroponics system.
IntermediateShowcase (no instructions)16,986
Things used in this project
Hardware components
LED Light Bar, Daylight
×1
Raspberry Pi 3 Model B
×1
Relay Module (Generic)
×1
pH Sensor Kit
Atlas Scientific pH Sensor Kit
×1
Humidity and Temperature Sensor
Adafruit Humidity and Temperature Sensor
×1
ZX Distance and Gesture Sensor
SparkFun ZX Distance and Gesture Sensor
×1
Grove - Digital Light Sensor
Seeed Grove - Digital Light Sensor
×1
Toggle Switch, Toggle
×1
EZO-PMP™ Peristaltic Pump
Atlas Scientific EZO-PMP™ Peristaltic Pump
×1
Axial Fan, 12 VDC
Axial Fan, 12 VDC
×1
Air pump
×1
Water pump
×1
Solenoid Valve, 2 Way
×1
Arduino IDE
Arduino IDE
Universal Windows Platform (UWP)-Visual studio community 2019
Laser cutter (generic)
Soldering iron (generic)
Solder Wire, Lead Free
Story
Read more
Code
Final Compilation on Arduino
C/C++
using serialevent and switch case functions
#include <SHT1x.h> //fan library
#include <math.h>
//general define
char ID = 0;
String CMD = "";
int subID = 0;
bool split = false;
//light
int percent = 0;
int relay1 = 22;
int relay2 = 23;
int relay3 = 24;
int pinBright = 2;
//fan - Specify data and clock connections and instantiate SHT1x object
#define dataPin  10
#define clockPin 11
SHT1x sht1x(dataPin, clockPin);
//Inital value
float Temperature = 0.0;
float Humidity = 0.0;
bool fanauto = false;
int relay4 = 25;
int relay5 = 26;
int relay6 = 27;
int relay7 = 28;
//water level
bool waterlevelauto = false;
const int trigPin = 6;
const int echoPin = 7;
long duration;
int distance;
int water_max = 15;
int water_level = 0;
int inputWL = 0;
int relay8 = 29;
int relay9 = 30;
//air pump
int relay10 = 31;
// nutrient pump
bool circularauto = false;
//data collection (to monitor)
float temp = 0.0;
float humi = 0.0;
String pH = "";
  Serial.begin (9600);
  Serial1.begin (9600);
  Serial2.begin (9600);
  CMD.reserve(20);
  pinMode (relay1, OUTPUT);
  pinMode (relay2, OUTPUT);
  pinMode (relay3, OUTPUT);
  pinMode (pinBright, OUTPUT);
  pinMode (relay4, OUTPUT);
  pinMode (relay5, OUTPUT);
  pinMode (relay6, OUTPUT);
  pinMode (relay7, OUTPUT);
  pinMode (relay8, OUTPUT);
  pinMode (relay9, OUTPUT);
  pinMode (relay10, OUTPUT);
  pinMode (trigPin, OUTPUT);
  pinMode (echoPin, INPUT);
   temp = sht1x.readTemperatureC();
   humi = sht1x.readHumidity();
   Round_Temperature(temp);
   Serial2.print ('R');
   Serial2.print ('\r');
   delay (1000);
   pH = Serial2.readStringUntil(13);
   digitalWrite(trigPin, LOW);
   delayMicroseconds(2);
   digitalWrite(trigPin, HIGH);
   delayMicroseconds(10);                // Sets the trigPin on HIGH state for 10 micro seconds
   duration = pulseIn(echoPin, HIGH);    // Reads the echoPin, returns the sound wave travel time in microseconds
   distance = duration*0.034/2;          // Calculating the distance
   water_level = water_max-distance;
   Serial.print ("Temperature: ");
   Serial.print (temp);
   Serial.print ("C || ");
   Serial.print ("Humidity: ");
   Serial.print (humi);
   Serial.print ("% || ");
   Serial.print ("pH: ");
   Serial.print (pH);
   Serial.print (" || ");
   Serial.print ("Water Level: ");
   Serial.print (water_level);
   Serial.println ("cm ");
   delay (3000);
  if (fanauto == true)
    Temperature = sht1x.readTemperatureC();
    Humidity = sht1x.readHumidity();
    Round_Temperature(Temperature);
    if (Temperature >= 28)
      digitalWrite (relay7, HIGH);
    if (Temperature < 28)
      digitalWrite (relay7, LOW);
  if (waterlevelauto == true)
    if (water_level < inputWL)
      digitalWrite (relay8, HIGH);
      digitalWrite (relay9, LOW);
    if (water_level > inputWL)
      digitalWrite (relay8, LOW);
      digitalWrite (relay9, HIGH);
  if (circularauto == true)
  if (circularauto == false)
void Round_Temperature(float input_temp)
  input_temp = input_temp*100;
  input_temp = round(input_temp);
  input_temp = input_temp*0.01;
void serial3Event()
  while (Serial3.available())
    char inChar = (char)Serial3.read();//receive one byte
    if(inChar==',')
      split = true;
    if(split==false)//split char before ','
      ID = inChar;
    if(split==true)//split char after ','
      if(inChar!=',' & inChar!='.')
        CMD += inChar;
    if (inChar == '.')
      switch(ID)
        case 'L': //lights
          if (CMD == "A") //auto mode
            digitalWrite (relay1, LOW);
            digitalWrite (relay2, LOW);
            digitalWrite (relay3, LOW);
          if (CMD == "S") //switch mode
            digitalWrite (relay1, HIGH);
            digitalWrite (relay2, HIGH);
          if (CMD == "RO") //remote mode
            digitalWrite (relay3, HIGH);
          if (CMD == "RF")
        break;
        case 'B': //brightness
          percent = CMD.toInt() ;
          percent = (percent * 2.25);
          analogWrite (pinBright, percent);
        break;
        case 'F': //fan
          if (CMD == "A")
            fanauto = true;
          if (CMD == "S") //Switch Mode
            digitalWrite (relay4, HIGH);
            digitalWrite (relay5, HIGH);
            digitalWrite (relay6, LOW);
            fanauto = false;
          if (CMD == "RO")
            digitalWrite (relay5, LOW);
            digitalWrite (relay6, HIGH);
            fanauto = false;
          if (CMD == "RF")
            fanauto = false;
        break;
        case 'N':
            circularauto = true;
            Serial1.print ("D," + CMD);
            Serial1.print ('\r');
            if (CMD == "S")
        break;
        case 'W': //water level
            inputWL = CMD.toInt ();
            if (inputWL >= 5 & inputWL <= 14)
              waterlevelauto = true;
            if (inputWL < 5)
              Serial.println ("Invalid water level: must be between 5 and 14 cm");
            if (inputWL > 14)
        break;
        case 'P': //water pump
          if (CMD == "O")
          if (CMD == "F")
        break;
        case 'V': //valve
          if (CMD == "O")
          if (CMD == "F")
        break;
        case 'A': //airpump
          if (CMD == "O")
            digitalWrite (relay10, HIGH);
          if (CMD == "F")
            digitalWrite (relay10, LOW);
        break;
        default:
        break;
      split = false;        //reset value
      ID = 0;               //reset value
      CMD = "";             //reset value
Credits
kkim20
kkim20
1 project • 10 followers
Comments
Add projectSign up / Login
