Kutluhan Aktar
Published © CC BY
Arduino RFID Reading Time Checker with MP3 Player and RTC
Set the alarm and activate it with an RFID card or tag to get notified with your favorite songs when the reading time is over.
AdvancedFull instructions provided1 hour233
Things used in this project
Hardware components
Seeed RFID Reading Time Checker PCB
×1
Arduino Nano R3
Arduino Nano R3
×1
SparkFun Nokia 5110 Screen
×1
Serial MP3 Player with Speaker (UART)
×1
Micro SD Card
×1
DS3231 RTC Module
×1
MFRC522 RFID Module
×1
Resistor 1k ohm
Resistor 1k ohm
×5
Resistor 220 ohm
Resistor 220 ohm
×4
Push Button
×4
KiCad
KiCad
Arduino IDE
Arduino IDE
Hot glue gun (generic)
Story
Read more
Custom parts and enclosures
Gerber
Fabrication
BOM
Serial MP3 Player Manual by OPEN-SMART
Clock (Icon)
Spider-Man (Icon)
Schematics
Fabrication
PCB
Code
Reading_Time_Checker_with_MP3_Player.ino
Arduino
        //       RFID Book Reading Time Checker with      //
       //               MP3 Player and RTC               //
     //                 Arduino Nano                   //
    //               by Kutluhan Aktar                //
// Connections
// Arduino Nano v3:
//                                Serial MP3 Player Module (OPEN-SMART)
// D8 --------------------------- TX
// D7 --------------------------- RX
//                                Nokia 5110 Screen
// D2 --------------------------- SCK (Clk)
// D3 --------------------------- MOSI (Din)
// D4 --------------------------- DC
// D5 --------------------------- RST
// D6 --------------------------- CS (CE)
//                                DS3231
// SDA(or A4) ------------------- SDA
// SCL(or A5) ------------------- SCL
//                                MFRC522
// D9  -------------------------- RST
// D10 -------------------------- SDA
// D11 -------------------------- MOSI
// D12 -------------------------- MISO
// D13 -------------------------- SCK
//                                LEFT_BUTTON
// A0 --------------------------- S
//                                OK_BUTTON
// A1 --------------------------- S
//                                RIGHT_BUTTON
// A2 --------------------------- S
//                                EXIT_BUTTON
// A3 --------------------------- S
// Include required libraries:
#include <SoftwareSerial.h>
#include <LCD5110_Basic.h>
#include <DS3231.h>
#include <EEPROM.h>
#include <SPI.h>
#include <MFRC522.h>
// Define the RX and TX pins to establish UART communication with the MP3 Player Module.
#define MP3_RX 8 // to TX
#define MP3_TX 7 // to RX
// Define the required MP3 Player Commands.
// You can inspect all given commands from the project page:
// Select storage device to TF card
static int8_t select_SD_card[] = {0x7e, 0x03, 0X35, 0x01, 0xef}; // 7E 03 35 01 EF
// Play the song with the directory: /01/001xxx.mp3
static int8_t play_first_song[] = {0x7e, 0x04, 0x41, 0x00, 0x01, 0xef}; // 7E 04 41 00 01 EF
// Play the song with the directory: /01/002xxx.mp3
static int8_t play_second_song[] = {0x7e, 0x04, 0x41, 0x00, 0x02, 0xef}; // 7E 04 41 00 02 EF
// Play the song.
static int8_t play[] = {0x7e, 0x02, 0x01, 0xef}; // 7E 02 01 EF
// Pause the song.
static int8_t pause[] = {0x7e, 0x02, 0x02, 0xef}; // 7E 02 02 EF
// Define the Serial MP3 Player Module.
SoftwareSerial MP3(MP3_RX, MP3_TX);
// Define the Nokia screen.
LCD5110 myGLCD(2,3,4,5,6);
extern uint8_t SmallFont[];
extern uint8_t MediumNumbers[];
extern uint8_t BigNumbers[];
// Define images for the graphics screen.
extern uint8_t clock[];
extern uint8_t spidey[];
// Initiate the DS3231 RTC Module using SDA and SCL pins.
DS3231  rtc(SDA, SCL);
// Define a time variable to get data from DS3231 properly.
Time t;
// Create MFRC522 instance.
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);
// Define MFRC5222 module key input.
MFRC522::MIFARE_Key key;
// Stores scanned ID read from the RFID Module.
byte readCard[4];
// Define registeredUID and lastRead strings.
String registeredUID, lastRead;
// Define the control buttons.
#define B_Exit A3
#define B_Right A2
#define B_OK A1
#define B_Left A0
// Define the data holders.
int Right, OK, Left, Exit;
int alarmHour =0;
int alarmMin = 0;
int selected = 0;
// Define the interface options:
volatile boolean Init_Checker = false;
volatile boolean Set_Checker = false;
volatile boolean Clock = false;
volatile boolean New_Card = false;
volatile boolean Activated = false;
volatile boolean Alarm_Mode = false;
  pinMode(B_Exit, INPUT);
  pinMode(B_Right, INPUT);
  pinMode(B_OK, INPUT);
  pinMode(B_Left, INPUT);
  // Initiate the serial moinitor.
  Serial.begin(9600);
  // Initiate the Serial MP3 Player Module.
  MP3.begin(9600);
  // Select the SD Card.
  send_command_to_MP3_player(select_SD_card, 5);
  // Start the rtc object.
  rtc.begin();
  // MFRC522 Hardware uses SPI protocol
  SPI.begin();
  // Initialize MFRC522 Hardware
  mfrc522.PCD_Init();
  // Initiate the Nokia screen.
  myGLCD.InitLCD();
  myGLCD.setFont(SmallFont);
  myGLCD.print("Initializing...", 0, 8);
  myGLCD.clrScr();
  read_control_buttons();
  select_menu_commands();
  home_screen();
  // Adjust the interface view depending on the selected option.
  if(Init_Checker == true){
    do{
      myGLCD.invertText(true);
      myGLCD.print("A.Init Checker", 0, 16);
      myGLCD.invertText(false);
      // If selected, initiate the alarm mode and activate the alarm when the registered UID is detected by the RFID Module (MFRC522).
      if(OK == true){
        myGLCD.clrScr();
        Activated = true;
        myGLCD.print("Approximate", 0, 0);
        myGLCD.print("the registered", 0, 8);
        myGLCD.print("card or key", 0, 16);
        myGLCD.print("to activate", 0, 24);
        myGLCD.print("the alarm", 0, 32);
        myGLCD.print("mode :)", 0, 40);
        // Get the registered UID in the EEPROM.
        get_the_registered_UID();
        while(Activated == true){
          // Read control variables.
          // Get the last detected UID from MFRC522.
          get_the_last_detected_UID();
          // If the detected UID corresponds to the registered UID in the EEPROM, then activate the alarm mode.
          if(lastRead == registeredUID){
            myGLCD.clrScr();
            Alarm_Mode = true;
            // ---------- Alarm Mode -------------
            if(Alarm_Mode == true){
              // Draw the alarm mode icon.
              myGLCD.drawBitmap(22, 0, clock, 40, 40);
              boolean song = false;
              while(Alarm_Mode == true){
                // Get the date and time information from the DS3231 RTC Module.
                get_time_rtc();
                // If the RTC Module hits the given reading alarm time, then start the MP3 Player.
                if(t.hour == alarmHour && t.min == alarmMin && song == false){
                  // Send commands to the MP3 Player Module.
                  send_command_to_MP3_player(play_second_song, 6);
                  // Draw the notification icon - I used a Spider-Man logo because the MP3 Player plays his cartoon's sountrack :)
                  myGLCD.clrScr();
                  myGLCD.drawBitmap(22, 0, spidey, 40, 40);
                  song = true;
                // MP3 Player Settings:
                // Play or pause selected songs for fun while the module is in the alarm mode :)
                if(Right == true) send_command_to_MP3_player(play_first_song, 6);
                if(Left == true) send_command_to_MP3_player(pause, 4);
                if(OK == true) send_command_to_MP3_player(play, 4);
                // Exit.
                if(Exit == true){ Alarm_Mode = false; myGLCD.clrScr(); lastRead = ""; registeredUID = "";}
          }else{
            // Blank the lastRead string after false readings.
            lastRead = "";
          // Exit.
          if(Exit == true){ Activated = false; myGLCD.clrScr(); registeredUID = "";}
    }while(Init_Checker == false);
  if(Set_Checker == true){
    do{
      myGLCD.print("B.Set Checker", 0, 24);
      // If selected, set the reading alarm to get notified when the RTC hits the given time (such as 18 : 37).
      if(OK == true){
        myGLCD.clrScr();
        Activated = true;
          // Display the reading alarm.
          myGLCD.setFont(BigNumbers);
          myGLCD.printNumI(alarmHour, LEFT, 0);
          myGLCD.printNumI(alarmMin, RIGHT, 0);
          myGLCD.print(".", CENTER, 0);
          myGLCD.print(".", CENTER, 16);
          myGLCD.print("DEC< Set >INC", CENTER, 40);
          // Set the reading alarm.
          if(Right == true) alarmMin++;
          if(Left == true) alarmMin--;
          if(alarmMin < 0){ alarmMin = 59; alarmHour--; myGLCD.clrScr(); }
          if(alarmMin > 59){ alarmMin = 0; alarmHour++; myGLCD.clrScr(); }
          if(alarmHour < 0) alarmHour = 23;
          if(alarmHour > 23) alarmHour = 0;
          delay(100);
          // Exit.
          if(Exit == true){ Activated = false; myGLCD.clrScr(); }
    }while(Set_Checker == false);
  if(Clock == true){
    do{
      myGLCD.print("C.Clock", 0, 32);
      // If selected, display date and time on the screen.
      if(OK == true){
        myGLCD.clrScr();
        Activated = true;
          get_time_rtc();
          myGLCD.printNumI(t.hour, LEFT, 0);
          myGLCD.printNumI(t.min, RIGHT, 0);
          myGLCD.print(String(rtc.getTemp()) + "'C", CENTER, 32);
          String d = String(t.date) + "/" + rtc.getMonthStr() + "/" + String(t.year);
          myGLCD.print(d, CENTER, 40);
          // Exit.
    }while(Clock == false);
  if(New_Card == true){
    do{
      myGLCD.print("D.New Card", 0, 40);
      // If selected, approximate a new card or key tag to scan and save the new UID to EEPROM.
      if(OK == true){
        myGLCD.clrScr();
        Activated = true;
        myGLCD.print("a new card or", 0, 8);
        myGLCD.print("key tag to", 0, 16);
        myGLCD.print("scan and save", 0, 24);
        myGLCD.print("the new UID to.", 0, 32);
        myGLCD.print("EEPROM :)", 0, 40);
          // Register a new UID (card or tag) to save it to the EEPROM.
          register_new_card();
          // Exit.
    }while(New_Card == false);
void read_control_buttons(){
  // Read the control buttons:
  Right = digitalRead(B_Right);
  OK = digitalRead(B_OK);
  Left = digitalRead(B_Left);
  Exit = digitalRead(B_Exit);
void send_command_to_MP3_player(int8_t command[], int len){
  Serial.print("\nMP3 Command => ");
  for(int i=0;i<len;i++){ MP3.write(command[i]); Serial.print(command[i], HEX); }
void get_time_rtc(){
  //  The following lines can be uncommented to set the date and time manually.
  //  rtc.setDOW(WEDNESDAY);     // Set Day-of-Week to Wednesday
  //  rtc.setTime(18, 13, 15);     // Set the time to 12:00:00 (24hr format)
  //  rtc.setDate(17, 10, 2018);   // Set the date to October 17st, 2018
  // Get the current hour and minute from DS3231. // t.hour; and t.min;
  t = rtc.getTime();
void register_new_card(){
  // Detect the new card UID.
  if ( ! mfrc522.PICC_IsNewCardPresent()) { return 0; }
  if ( ! mfrc522.PICC_ReadCardSerial()) { return 0; }
  // Display the new UID.
  for (int i = 0; i < mfrc522.uid.size; i++) {
    readCard[i] = mfrc522.uid.uidByte[i];
  // Save the new UID to EEPROM.
  // If you want to save another card, use i+4(...) instead i.
  for (int i = 0; i < mfrc522.uid.size; i++){
    EEPROM.write(i, readCard[i]);
  mfrc522.PICC_HaltA();
  // Return the success message.
  myGLCD.clrScr();
  myGLCD.print("Registered", 0, 8);
  myGLCD.print("Successfully!", 0, 24);
void get_the_registered_UID(){
  // Get the registered UID from EEPROM.
  for(int i=0;i<4;i++){
    registeredUID += EEPROM.read(i) < 0x10 ? " 0" : " ";
    registeredUID += String(EEPROM.read(i), HEX);
  // Arrange registeredUID for comparing.
  registeredUID.trim();
  registeredUID.toUpperCase();
  Serial.println("\nRegistered UID => " + registeredUID);
void get_the_last_detected_UID(){
  if ( ! mfrc522.PICC_IsNewCardPresent()){ return 0; }
  if ( ! mfrc522.PICC_ReadCardSerial()){ return 0; }
  for(int i=0;i<mfrc522.uid.size;i++){
    lastRead += mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ";
    lastRead += String(mfrc522.uid.uidByte[i], HEX);
   // Arrange lastRead for comparing.
   lastRead.trim();
   lastRead.toUpperCase();
   Serial.println("\nLast Detected UID => " + lastRead);
void home_screen(){
  // Define options.
  myGLCD.print("Menu Commands:", 0, 0);
void select_menu_commands(){
  // Increase or decrease the option number using Right and Left buttons.
  if(Right == true) selected++;
  if(Left == true) selected--;
  if(selected < 0) selected = 4;
  if(selected > 4) selected = 1;
  delay(300);
  // Depending on the selected option number, change boolean status.
  switch(selected){
    case 1:
      Init_Checker = true;
      Clock = false;
      New_Card = false;
    break;
    case 2:
      Set_Checker = true;
      Clock = false;
      New_Card = false;
    break;
    case 3:
      Clock = true;
      New_Card = false;
    break;
    case 4:
      Clock = false;
      New_Card = true;
    break;
Credits
Kutluhan Aktar
Kutluhan Aktar
30 projects • 66 followers
Self-Taught Full Stack Developer | Programmer | Maker | Physics Enthusiast
Comments
Add projectSign up / Login
