Kutluhan Aktar
Published © CC BY
Nano Weather Shield V1.1
Display weather information and activate RGB color patterns via this shield, including built-in BMP280 and photoresistor, designed by me.
ExpertFull instructions provided2 hours1,501
Things used in this project
Hardware components
Seeed Nano Weather Shield V1.1
×1
Arduino Nano R3
Arduino Nano R3
×1
Alphanumeric LCD, 20 x 4
×1
Arduino IDE
Arduino IDE
KiCad
KiCad
Story
Read more
Custom parts and enclosures
Gerber Files
Fabrication Files
Eeschema
BOM File
Schematics
Eeschema
Footprint
Pcbnew
Code
Arduino Nano Code
Arduino
        //       Nano_Weather_Shield_V1.1          //
     //             (Arduino Nano)              //
    //             by Kutluhan Aktar           //
// Following code is for Nano Weather Shield V1.1 by TheAmplituhedron.
// You can get more information about the features and specifications of the shield
// and download all gerber and fabrications files from the link below.
// https://www.theamplituhedron.com/projects/Nano-Weather-Shield-V1.1/
// Connections
// Nano_Weather_Shield_V1.1 :
//                                16x2 or 20x4 LCD Screen
// D12 --------------------------- rs
// D11 --------------------------- en
// D5  --------------------------- D4
// D4  --------------------------- D5
// D3  --------------------------- D6
// D2  --------------------------- D7
//                                RGB LED
// D6  --------------------------- r
// D9  --------------------------- g
// D10 --------------------------- b
//                                BMP280 Pressure and Temperature Sensor
// A4 --------------------------- SDI
// A5 --------------------------- SCK
//                                Vibration Sensor
// A3 --------------------------- S
//                                Photoresistor
// A0 --------------------------- S
//                                Button_1
// A1 ---------------------------
//                                Button_2
// A2 ---------------------------
// include the required libraries for the BMP280 Temperature and Pressure Sensor
#include <Wire.h>
#include <Adafruit_BMP280.h>
// include the LiquidCrystal library:
#include <LiquidCrystal.h>
Adafruit_BMP280 bmp; // I2C
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// define sensors' signal pins.
#define Photo_Pin A0
#define Vibra_Pin A3
//define RGB pins
#define R 6
#define G 9
#define B 10
// define button pins
#define button_1 A1
#define button_2 A2
// define screen booleans so as to switch between screens - SCREEN_2 is the home screen.
boolean SCREEN_1 = true;
boolean SCREEN_2 = false;
boolean SCREEN_3 = false;
// define data holders
int swb_1, swb_2, photoresistor, vibration;
float temperature, pressure;
int screen_number = 0;
  Serial.begin(9600);
  pinMode(R, OUTPUT);
  pinMode(G, OUTPUT);
  pinMode(B, OUTPUT);
  analogWrite(R, 255);
  analogWrite(G, 255);
  analogWrite(B, 255);
  // set up the LCD's number of columns and rows:
  lcd.begin(20, 4);
  // BMP280 Settings
  if (!bmp.begin()) {
    Serial.println(F("Could not find a valid BMP280 sensor, check wiring!"));
    while (1);
  /* Default settings from datasheet. */
  bmp.setSampling(Adafruit_BMP280::MODE_NORMAL,     /* Operating Mode. */
                  Adafruit_BMP280::SAMPLING_X2,     /* Temp. oversampling */
                  Adafruit_BMP280::SAMPLING_X16,    /* Pressure oversampling */
                  Adafruit_BMP280::FILTER_X16,      /* Filtering. */
                  Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
  if(SCREEN_1 == true){
    lcd.clear();
    while(SCREEN_1 == true){
        get_Sensor_Readings();
        get_SWB_Values();
        assign_screen_number();
        lcd.setCursor(0,0);
        lcd.print("Temperature: " + String((int)temperature) + " *C");
        lcd.setCursor(0, 1);
        lcd.print("Pressure: " + String(pressure / 100) + "hPa");
        lcd.setCursor(0, 3);
        lcd.print("Light D.->");
  }else if(SCREEN_2 == true){
    lcd.clear();
    while(SCREEN_2 == true){
        get_SWB_Values();
        lcd.setCursor(0,0);
        lcd.print("Light Density : " + String(photoresistor) + "%");
        lcd.print("Vibration : " + String(vibration));
        lcd.print("<-Temp|RGB->");
  }else if(SCREEN_3 == true){
    lcd.clear();
    while(SCREEN_3 == true){
        lcd.setCursor(0,0);
        lcd.print("RGB Color Theme");
        lcd.setCursor(0,1);
        lcd.print("is Activated :)");
        lcd.print("<-Light D.");
        // create a unique RGB Color Theme
        RGB(255, 0, 0);
        RGB(0, 255, 0);
        RGB(0, 0, 255);
        RGB(255, 255, 0);
        RGB(255, 0, 255);
        RGB(0, 255, 255);
        RGB(42, 252, 5);
        RGB(255, 130, 5);
        RGB(26, 5 , 252);
        RGB(255, 255, 255);
        RGB(0, 0, 0);
void get_Sensor_Readings(){
  photoresistor = map(analogRead(Photo_Pin), 0, 1023, 0, 100);
  vibration = analogRead(Vibra_Pin);
  temperature = bmp.readTemperature();
  pressure = bmp.readPressure();
void get_SWB_Values(){
  swb_1 = analogRead(button_1);
  swb_2 = analogRead(button_2);
void assign_screen_number(){
  if(swb_1 > 1020){
     screen_number--;
     delay(500);
  if(swb_2 > 1020){
     screen_number++;
     delay(500);
  if(screen_number > 2){ screen_number = 0;}if(screen_number < 0){ screen_number = 2; }
  // change screens
  switch(screen_number){
    case 0:
     SCREEN_1 = true;
     SCREEN_2 = false;
     SCREEN_3 = false;
    break;
    case 1:
     SCREEN_1 = false;
     SCREEN_2 = true;
     SCREEN_3 = false;
    break;
    case 2:
     SCREEN_1 = false;
     SCREEN_2 = false;
     SCREEN_3 = true;
    break;
void RGB(int x, int y, int z){
  analogWrite(R, 255 - x);
  analogWrite(G, 255 - y);
  analogWrite(B, 255 - z);
  // check if there is a change in the screen number after a color shift
  get_SWB_Values();
Credits
Kutluhan Aktar
Kutluhan Aktar
32 projects • 73 followers
Self-Taught Full Stack Developer | Programmer | Maker | Physics Enthusiast
Comments
Add projectSign up / Login
