Mayank Mohan
Published
Smoke Level Detector with Alarm
The level of Smoke in our Surrounding because of combustion. So, We can sense the amount of smoke and generate an alert signal.
BeginnerFull instructions provided1 hour1
Things used in this project
Hardware components
Arduino UNO & Genuino UNO
×1
Grove - Gas Sensor(MQ2)
Seeed Grove - Gas Sensor(MQ2)
×1
Buzzer
Buzzer
×1
LED (generic)
LED (generic)
×1
Jumper wires (generic)
×1
Resistor 330 ohm
Resistor 330 ohm
×1
RGB Backlight LCD - 16x2
Adafruit RGB Backlight LCD - 16x2
×1
USB-A to B Cable
USB-A to B Cable
×1
Breadboard (generic)
×1
Arduino IDE
Arduino IDE
Story
Read more
Schematics
Schematic Diagram of Smoke Detector
Code
Arduino Code of Smoke Detector
Arduino
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
int redLed = 10;
int greenLed = 12;
int buzzer = 8;
int smokeA0 = A0;
// Your threshold value
int sensorThres = 100;
  pinMode(redLed, OUTPUT);
  pinMode(buzzer, OUTPUT);
  pinMode(smokeA0, INPUT);
  Serial.begin(9600);
  lcd.begin(16,2);
  int analogSensor = analogRead(smokeA0);
  Serial.print("Pin A0: ");
  Serial.println(analogSensor);
  lcd.print("Smoke Level:");
  lcd.print(analogSensor-50);
  // Checks if it has reached the threshold value
  if (analogSensor-50 > sensorThres)
    digitalWrite(redLed, HIGH);
    lcd.setCursor(0, 2);
    lcd.print("Alert....!!!");
    digitalWrite(12, LOW);
    tone(buzzer, 1000, 200);
  else
    digitalWrite(redLed, LOW);
    digitalWrite(12, HIGH);
    lcd.print(".....Normal.....");
    noTone(buzzer);
  delay(500);
  lcd.clear();
Credits
Mayank Mohan
Mayank Mohan
1 project • 0 followers
Comments
Add projectSign up / Login
