Navin Bhaskar
Published © MIT
C/C++ on Intel Edison/Galileo – part5:Temperature sensor
In this part, we will interface a temperature sensor to Galileo/Edison
BeginnerFull instructions provided30 minutes3
Things used in this project
Story
Read more
Code
Code snippet #1
Plain text
#include <stdio.h>
#include <mraa.h>
#include <math.h>           // for the log function
const int B  = 4275;         // B value for thermistor
const int R0 = 100;          // R0 is 100k ohms
#define TEMP_ADC_PIN    0    // ADC pin is 0
int main(void)
    mraa_aio_context   adcPin;           // used as AIO context
    float              adcValue;         // ADC value read into this variable
    float              R, temperature;   // Used in calculations
    /* Step1: Initialize the mraa */
    mraa_init();
    /* Step2: Initlaize the ADC pin */
    adcPin = mraa_aio_init(TEMP_ADC_PIN);
    /* Step3: Read the ADC value */
    adcValue = mraa_aio_read(adcPin);
    /* Step4: Apply the transformation */
    R = 1023.0/((float)adcValue)-1.0;    // Promote to float
    R = 100000.0*R;
    temperature = 1.0/(log(R/100000.0)/B+1/298.15)-273.15;
    /* Step5: Print the temperature */
    printf ("The temperature is %0.2f degree Celcius\n", temperature);
    return 0;
Code snippet #4
Plain text
R = 100000.0*R;
Code snippet #7
Plain text
#include <stdio.h>  // for printf()
/* Step1: Bring in the upm */
#include <upm/grove.h>
int main(void)
    int temperature;
    /* Step2: Instantiate an instance of Grove temperature sensor */
    upm::GroveTemp *temp = new upm::GroveTemp(TEMP_ADC_PIN);
    /* Step3: Record the temperature and print */
    temperature = temp->value();
    printf ("The temperature is %d degree Celcius\n", temperature);
    return 0;
Credits
Navin Bhaskar
Navin Bhaskar
10 projects • 2 followers
Comments
Add projectSign up / Login
