Nile Mittow
Published © GPL3+
RFID Front Door Access Control
Use Edison to interface with an existing member management system to control and management egress into a facility.
IntermediateWork in progress10 hours1,822
Things used in this project
Hardware components
Intel Edison
Intel Edison
×1
Solderless Breadboard Full Size
×1
Parallax Serial RFID Reader
×1
Grove starter kit plus for Intel Edison
Seeed Grove starter kit plus for Intel Edison
Only using the RGB LCD & Optional Buzzer
×1
NTE40107B - CMOS NAND Gate
Can probably substitute any NAND gate CMOS IC
×1
NTE4071B - CMOS OR Gate
Can probably substitute and OR gate CMOS IC
×1
Rotary potentiometer (generic)
20k is best, 50k or 100k would work.
×1
Resistor 1k ohm
Resistor 1k ohm
×5
555 or 556 Timer (generic)
×1
680uF Capacitor
×1
5v DPDT Relay
×1
Capacitor 10 nF
Capacitor 10 nF
×1
NTE 490 - N Channel MOSFET Enhancement Mode High-Speed switch
Any n-channel logic level MOSFET should work. Needed because Edison's GPIO pins can't source enough current to drive a 5v relay directly
×1
Terminal Blocks
Each should have 3 screw terminals,
×2
Electromagnetic or Solenoid actuated door lock
This is part of the door to be controlled, so what to use is heavily dependant on your situation. https://www.amazon.com/Seco-Larm-941SA-600-Enforcer-Electromagnetic-Holding/dp/B00196YB5Y as an example
×1
vim
ssh
Online Member Management Service
Mine interfaces with a system called Nexudus, but the source of the database can be anything that can return member info via api calls. If necc, and if the system does not need to dynamically update the entry list, a static DB is sufficient.
sqlite
lib required
JSON-C
lib required
Story
Read more
Custom parts and enclosures
RFID Door Enclosure Box for Lasercutting
Mostly 3mm Acrylic but check layer names
Schematics
RFID Door Circuit Fritzing Diagram
Some of the components could easily be substituted (Logic gate ICs for instance) but the gist of the circuit is here.
Code
RFID Door Access Control Code
Credits
Nile Mittow
Nile Mittow
3 projects • 2 followers
Comments
Add projectSign up / Login
