Emmanuel CollinThéo PaillierRené - Mervis MUDRY
Published © GPL3+
NMF Atlantis
Flood detection system through water level measurements. Data transmission using Sigfox LPWAN. Real-time monitoring and alerts on Ubidots.
AdvancedShowcase (no instructions)24 hours251
NMF Atlantis
Things used in this project
Hardware components
Nucleo 144 STM32F7
ST STM32L4, STM32F7 Nucleo 144 STM32F7
×1
DHT22 Temperature Sensor
×1
Sigfox Breakout board BRKWS01
×1
Grove - Ultrasonic Ranger
Seeed Grove - Ultrasonic Ranger
×1
3.7V 1050mAh LiPo Battery
×1
2W Solar Panel
×1
Plastic Enclosure, Proj box
×1
Resistor 10k ohm
Resistor 10k ohm
×2
Resistor 2.21k ohm
Resistor 2.21k ohm
×1
Pololu S7V8F5
×1
Capacitor 4.7 µF
Capacitor 4.7 µF
×2
MCP73831 Single Cell, Li-Ion/Li-Polymer Charge Management Controller
×1
Ubidots
Ubidots
Sigfox
Sigfox
Mbed Studio
Arm Mbed Mbed Studio
KiCad
KiCad
Solidworks
Soldering iron (generic)
Solder Wire, Lead Free
3D Printer (generic)
Hot glue gun (generic)
10 Pc. Jumper Wire Kit, 5 cm Long
Wire Stripper & Cutter, 18-10 AWG / 0.75-4mm² Capacity Wires
Story
Read more
Custom parts and enclosures
Support
Schematics
Supply schematic
Nucleo connections
Supply PCB
Main board PCB
KiCad - PCB Microcontroller
Can be printed with an appropriate PCB printer
KiCad - PCB Power Supply
Code
Main
C/C++
#include "mbed.h"
#include "DHT.h"
#include "Pulse.h"
#include "RangeFinder.h"
#include "WakeUp.h"
RangeFinder rf(D12, 10, 5800, 100000); //(Pin, duree du pulse en us, distance [m] = pulse width [us] / 5800 [us / m] , temps de fonctionnement)
DigitalOut led(LED1);
Serial serial(D1, D0);
Serial pc(USBTX, USBRX);
DHT HTSensor(D10,22);
AnalogIn battery(A1);
int main()
    pc.printf("Starting...\n\r\n\r");
    float d;
    int dInt;
    float temperature;
    int tInt;
    float humidity;
    int hInt;
    float b;
    int bInt;
    int cpt = 0;
    // En fonction du cours d'eau
    float Limite_sensor = 4.0*100.0;
    float Limite_danger = 50.0;
    int Temps_danger = 900;
    int Temps_default = 1800;
    int Intervalle_envoi = 3600; //Toutes les heures (1h = 3600 s)
    while (1)
        //Mesure niveau batterie réduite (entre 0 V et 1.85 V)
        b = battery.read()*3.3f;
        bInt = (int)(b*100/3.3f);
        pc.printf("Voltage = %f volts\r\n\r\n", b);
        pc.printf("Voltage code = %d percentage\r\n\r\n", bInt);
        //Mesures de temperature et humidite
        HTSensor.readData();
        wait_us(500);
        temperature = HTSensor.ReadTemperature(KELVIN) - 273,15;
        tInt = (int) (temperature + 40);
        humidity = HTSensor.ReadHumidity();
        hInt = (int) humidity;
        pc.printf("Temperature = %f degre C.\n\r", temperature);
        pc.printf("temp code = %d\n\r", tInt);
        pc.printf("temp Hex = %02x\n\r\n\r",tInt);
        pc.printf("Humidity = %f percentage.\n\r", humidity);
        pc.printf("hum code = %d\n\r", hInt);
        pc.printf("hum Hex = %02x\n\r\n\r",hInt);
        //Mesure distance
        d = rf.read_m();
        d = d*100;
        if (d < 0)
            d = 0;
            WakeUp::set(Temps_default); //temps en secondes
            deepsleep();
            cpt += Temps_default;
        else if (d >= Limite_sensor)
            d = Limite_sensor;
            // Seeed's sensor has a maximum range of 4m, it returns
            // something like 7m if the ultrasound pulse isn't reflected.
            deepsleep();
        else if (d <= Limite_danger) // Flood
            dInt = (int)d;
            //Envoi des informations
            serial.printf("AT$SF=%04x%02x%02x%02x\r\n",dInt,tInt,hInt, bInt);
            //Si danger, on l'envoie à chaque fois
            WakeUp::set(Temps_danger); //Temps en secondes
            deepsleep();
            cpt += Temps_danger;
        else
            deepsleep();
        if (cpt >= Intervalle_envoi)
            dInt = (int)d;
            cpt = 0;
NMF Atlantis Code
Files to be added to your mbed compiler
Credits
Emmanuel Collin
Emmanuel Collin
1 project • 0 followers
Théo Paillier
Théo Paillier
René - Mervis MUDRY
René - Mervis MUDRY
0 projects • 0 followers
Comments
Add projectSign up / Login
