Onwusoro Ifeanyi Emmanuel
Published © GPL3+
Smart Solar Public Hand wash/sanitizer machine(Arduino Nano)
As a digital company, our product is : Smart solar public hand sanitizer/wash that is controlled by a sensor Hereby reduce spread of virus.
IntermediateFull instructions providedOver 2 days68
Things used in this project
Hardware components
Metal Enclosure, Electrical / Industrial
×1
Grove - PIR Motion Sensor
Seeed Grove - PIR Motion Sensor
×1
100 watts, 12 volts Solar panel
×1
12 volts, Deep cycle rechargable battery (any design will do)
×1
500 watt inverter
×1
12v water DC pump (3 pcs)
×1
5v relay module (4 pcs)
×1
mini hair dryer ( used as hand dryer)
×1
Kitchen sink
×1
Hose pipe for water pump
×1
Jumper wires (generic)
×1
Tap head ( normal water tap head)
×1
3 Plastic containers( for liquid storage)
×1
Arduino Nano board
×1
Arduino IDE
Arduino IDE
Soldering iron (generic)
Solder Wire, Lead Free
Arduino nano board
Story
Read more
Custom parts and enclosures
Schematics
Pir diagram
Code
Arduino code
C/C++
Upload to the Arduino board
int pump1 = 9; // PUMP1
int pump2 = 5; // PUMP2
int pump3 = 6; // PUMP3
int dryer = 7; // Hand dryer
int inputPin = 8; // choose the input pin (for PIR sensor)
int val = 0; // variable for reading the pin status
pinMode(pump1, OUTPUT); // declare pump as output
pinMode(pump2, OUTPUT); // declare pump as output
pinMode(pump3, OUTPUT); // declare pump as output
pinMode(dryer, OUTPUT); // declare dryer as output
pinMode(inputPin, INPUT); // declare sensor as input
Serial.begin(9600);
void loop(){
val = digitalRead(inputPin); // read input value
Serial.println(val);
if( val == HIGH) {
digitalWrite(pump1,HIGH); // turn ON the soap pump
delay(5000);
digitalWrite(pump1,LOW); // turn OFF the pump
digitalWrite(pump2,HIGH); // turn ON the water pump
delay(20000);   //for 20 seconds
digitalWrite(pump2,LOW); // turn OFF the pump
digitalWrite(dryer,HIGH); // turn ON the hand dryer
delay(10000);
digitalWrite(dryer,LOW); // turn OFF the dryer
digitalWrite(pump3,HIGH); // turn ON the sanitizer pump
delay(5000);
digitalWrite(pump3,LOW); // turn OFF the pump
} else {
Credits
1 project • 0 followers
A graduate of Mechanical Engineering, I have been developing for 7 years plus, I love solving real life problems with innovative technology.
Comments
Add projectSign up / Login
