ozge_1
Published © LGPL
Lcd buzzer ve led ile gaz sensörü
Evinizde korkmadan yaşayın
IntermediateWork in progress98
Things used in this project
Hardware components
Grove - Gas Sensor(MQ2)
Seeed Grove - Gas Sensor(MQ2)
×1
Resistor 10k ohm
Resistor 10k ohm
×1
Rotary potentiometer (generic)
×1
5 mm LED: Green
5 mm LED: Green
×1
Buzzer
Buzzer
×1
Alphanumeric LCD, 16 x 2
×1
Arduino UNO & Genuino UNO
×1
Male/Male Jumper Wires
×15
Breadboard (generic)
×1
Arduino IDE
Arduino IDE
Story
Read more
Schematics
made with tincercad
Code
gaz uygulaması
BatchFile
#define sensor A0
#define led 3
#define buzzer 10
#include <LiquidCrystal.h>
LiquidCrystal(9,8,7,6,5,4);
pinMode(led,OUTPUT);
pinMode(buzzer,OUTPUT);
lcd.begin(16,2);
pinMode(sensor,INPUT);
Serial.begin(9600);
lcd.print("dikkat");
int sensordeger=analogRead(sensor);
Serial.print("sensrdeeri:");
Serial.println(sensordeger);
if (sensordeger>=350){
  digitalWrite(led,HIGH);
  digitalWrite(led,LOW);
  if(sensordeger>=600){
 digitalWrite(buzzer,HIGH);
 digitalWrite(buzzer,LOW);
else{
Credits
ozge_1
ozge_1
1 project • 0 followers
Comments
Add projectSign up / Login
