Daan van der WerfErwin van Ginkel
Published © GPL3+
Understanding night sweating during the menopause
Recording nocturnal perspiration patterns while sleeping
IntermediateShowcase (no instructions)1 hour214
Things used in this project
Hardware components
Seeeduino LoRaWAN
Seeeduino LoRaWAN
×1
SparkFun Soil Moisture Sensor (with Screw Terminals)
×1
Temperature Sensor
Temperature Sensor
×2
Carbon Wire
×1
Absorbent paper
×1
Story
Read more
Code
Q-Strip Source Node
Arduino
Getting 3 values from 2 analog TMP36 temp sensors and 1 groove moisture sensor and send them over LoRaWAN to store at TTN
#include <Wire.h>
#include <LoRaWan.h>
#include <math.h>
int tempPin   = A1; //temp sensor
int RtempPin  = A5; //temp room sensor
int sensorPin = A4; //input pin for the bed tempsensor
int sensorvalue;
char buffer[256];
void setup(void)
    //SerialUSB.begin(115200);
    //while(!SerialUSB);
    lora.init();
    memset(buffer, 0, 256);
    lora.getVersion(buffer, 256, 1);
    //SerialUSB.print(buffer);
    lora.getId(buffer, 256, 1);
  //lora.setId("Device Address", "Device EUI", "Application EUI");
  lora.setId("XXXXXXXXXXXX", "XXXXXXXXXXXXXX", "XXXXXXXXXXXXXXXX");
    //lora.setKey("Network Session Key", "App Session Key", NULL);
    lora.setKey("XXXXXXXXXXXXXXXXXXXXXXXXXXXX", "XXXXXXXXXXXXXXXXXXXXXXXXXXXX", "XXXXXXXXXXXXXXXXXXXXXXXXXXXX");
    lora.setDeciveMode(LWABP);
    lora.setDataRate(DR0, EU868);
    lora.setAdaptiveDataRate(1);
    lora.setChannel(0, 868.1);
    lora.setChannel(1, 868.3);
    lora.setChannel(2, 868.5);
    lora.setReceiceWindowFirst(0, 868.3);
    lora.setReceiceWindowSecond(869.5, DR3);
    lora.setDutyCycle(false);
    lora.setJoinDutyCycle(false);
    lora.setPower(20);
    lora.setPort(1);
void loop(void)
   bool result = false;
  delay (2000);
  int sensorvalue = analogRead(sensorPin);
  int moisture = sensorvalue * 100;
  delay (2000);
  int reading = analogRead(tempPin);
  float voltage = reading * 3.3;
  voltage /= 1024.0;
  int temperatureC = ((voltage - 0.5) * 100)* 100 ;
  delay (2000);
  int reading2 = analogRead(RtempPin);
  float voltage2 = reading2 * 3.3;
  voltage2 /= 1024.0;
  int temperatureR = ((voltage2 - 0.5) * 100)* 100 ;
  byte data[6];
    data[0] = temperatureC >> 8;
    data[1] = temperatureC & 0xFF;
    data[2] = moisture >> 8;
    data[3] = moisture & 0xFF;
    data[4] = temperatureR >> 8;
    data[5] = temperatureR & 0xFF;
   result = lora.transferPacket(data, 6);
    //TTN DOWNLINK
    if(result)
        short length;
        short rssi;
        length = lora.receivePacket(buffer, 256, &rssi);
        if(length)
            //SerialUSB.print("Length is: ");
            //SerialUSB.println(length);
            //SerialUSB.print("RSSI is: ");
            //SerialUSB.println(rssi);
            //SerialUSB.print("Data is: ");
            for(unsigned char i = 0; i < length; i ++)
                //SerialUSB.print("0x");
                //SerialUSB.print(buffer[i], HEX);
                //SerialUSB.print(" ");
            //SerialUSB.println();
    delay(60000);
Example dataset in CSV
Plain text
Gender: female, age : 40, BMI : 34.1
No preview (download only).
Credits
Daan van der Werf
Daan van der Werf
2 projects • 1 follower
Delphi developer over 15 years. Started combining IoT 4 years ago into my applications and focussed on innovating sensor techniques.
Erwin van Ginkel
Erwin van Ginkel
1 project • 1 follower
Supporting inventor Daan van der Werf to tell the world about the potential of nocturnal perspiration data.
Comments
Add projectSign up / Login
