Rei Vilo
Published © CC BY-SA
Contactless Temperature Monitor
How to check the temperature with no contact? The project combines PIR detection, IR camera and hand-gesture recognition for perfect safety.
IntermediateFull instructions provided1 hour1,000
Things used in this project
Hardware components
Seeed Wio Terminal
×1
Seeed Grove Gesture Sensor for Arduino (PAJ7620U2)
×1
Grove - mini PIR motion sensor
Seeed Grove - mini PIR motion sensor
×1
Seeed Grove AMG8833 8x8 Infrared Thermal Temperature Sensor Array
×1
Seeed Grove I²C Hub 6 Ports
×1
embedXcode
Arduino IDE
Arduino IDE
Node-RED
Node-RED
MQTT
MQTT
Story
Read more
Schematics
Finite-state machine diagram
The states and transitions of the project
Connections
Use dedicated fool-proof Grove Cables to connect the peripherals to the Wio Terminal.
Code
Contact-Less Temperature Project
Arduino sketch and Node-RED flow
Credits
Rei Vilo
Rei Vilo
10 projects • 21 followers
Comments
Add projectSign up / Login
