Siddharth
Published © GPL3+
ShareIt - Shared Mobility for the Post-COVID world
A shared mobility ecosystem that allows safe use of public vehicles
BeginnerFull instructions provided3 hours35
Things used in this project
Hardware components
Arduino MKR WiFi 1010
×1
SG90 Micro-servo motor
×1
Grove - Infrared Reflective Sensor v1.2
Seeed Grove - Infrared Reflective Sensor v1.2
×2
Jumper wires (generic)
×1
paper roll(generic)
×1
Gluesticks
×1
Arduino IDE
Arduino IDE
Ubidots
Ubidots
MIT App Inventor 2
MIT App Inventor 2
Soldering iron (generic)
Hot glue gun (generic)
Story
Read more
Schematics
Circuit Diagram
.png format circuit
Code
Android app for booking and getting access to paper
Java
No preview (download only).
Publish to ubidots
C/C++
 * Include Libraries
#include "UbidotsESPMQTT.h"
 * Define Constants
#define TOKEN "BBFF-HQzhjmDxosWtw94dhMISDcaLpZAzxK" // Your Ubidots TOKEN
#define WIFINAME "Moinak" //Your SSID
#define WIFIPASS "lklklklk" // Your Wifi Pass
Ubidots client(TOKEN);
 * Auxiliar Functions
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i=0;i<length;i++) {
    Serial.print((char)payload[i]);
  Serial.println();
 * Main Functions
  //client.ubidotsSetBroker("business.api.ubidots.com"); // Sets the broker properly for the business account
  client.setDebug(true); // Pass a true or false bool value to activate debug messages
  client.wifiConnection(WIFINAME, WIFIPASS);
  client.begin(callback);
  if(!client.connected()){
      client.reconnect();
  float value1 = analogRead(0);
  //float value2 = analogRead(2)
  client.add("temperature", value1);
  //client.add("status", value2);
  client.ubidotsPublish("my-new-device");
  client.loop();
Receive
C/C++
Code to get alerts from Ubidots
 * Include Libraries
#include <WiFi.h>
#include <PubSubClient.h>
#define WIFISSID "Moinak" // Put your WifiSSID here
#define PASSWORD "lklklklk" // Put your wifi password here
#define TOKEN "BBFF-HQzhjmDxosWtw94dhMISDcaLpZAzxK" // Put your Ubidots' TOKEN
#define MQTT_CLIENT_NAME "MeXhtUM0" // MQTT client Name, please enter your own 8-12 alphanumeric character ASCII string;
                                           //it should be a random and unique ascii string and different from all other devices
 * Define Constants
#define VARIABLE_LABEL "sensor" // Assing the variable label
#define DEVICE_LABEL "esp32" // Assig the device label
#define SENSOR 12 // Set the GPIO12 as SENSOR
char mqttBroker[]  = "industrial.api.ubidots.com";
char payload[100];
char topic[150];
// Space to store values to send
char str_sensor[10];
WiFiClient ubidots;
PubSubClient client(ubidots);
  char p[length + 1];
  memcpy(p, payload, length);
  p[length] = NULL;
  String message(p);
  Serial.write(payload, length);
  Serial.println(topic);
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.println("Attempting MQTT connection...");
    // Attemp to connect
    if (client.connect(MQTT_CLIENT_NAME, TOKEN, "")) {
      Serial.println("Connected");
    } else {
      Serial.print("Failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 2 seconds");
      // Wait 2 seconds before retrying
      delay(2000);
 * Main Functions
  WiFi.begin(WIFISSID, PASSWORD);
  // Assign the pin as INPUT
  pinMode(SENSOR, INPUT);
  Serial.println();
  Serial.print("Wait for WiFi...");
  while (WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
    delay(500);
  Serial.println("");
  Serial.println("WiFi Connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
  client.setServer(mqttBroker, 1883);
  client.setCallback(callback);
  if (!client.connected()) {
    reconnect();
  sprintf(topic, "%s%s", "/v1.6/devices/", DEVICE_LABEL);
  sprintf(payload, "%s", ""); // Cleans the payload
  sprintf(payload, "{\"%s\":", VARIABLE_LABEL); // Adds the variable label
  float sensor = analogRead(SENSOR);
  /* 4 is mininum width, 2 is precision; float value is copied onto str_sensor*/
  dtostrf(sensor, 4, 2, str_sensor);
  sprintf(payload, "%s {\"value\": %s}}", payload, str_sensor); // Adds the value
  Serial.println("Publishing data to Ubidots Cloud");
  client.publish(topic, payload);
  client.loop();
Credits
Siddharth
Siddharth
0 projects • 0 followers
IoT enthusiast specialising in Arduino, Raspberry Pi and FPGA based projects. ML and robotics lover.
Comments
Add projectSign up / Login
