MJ Guillet
Published
Holiday LED Sensor Display
Dynamically blinking Red & Green LED's (Grove sensors).
BeginnerWork in progress681
Things used in this project
Story
Read more
Code
main.js
JavaScript
A simple node.js application intended to blink Green and Red Gpio LED's in an alternating "holiday inspired" pattern on the Intel based development boards such as the Intel(R) Galileo and Edison with Arduino breakout board.
/*jslint node:true, vars:true, bitwise:true, unparam:true */
/*jshint unused:true */
var mraa = require('mraa'); //require mraa
console.log('MRAA Version: ' + mraa.getVersion()); //write the mraa version to the Intel XDK console
//istantiate green led
var myOnboardGLed = new mraa.Gpio(8); //Green LED hooked up to digital pin 8
myOnboardGLed.dir(mraa.DIR_OUT); //set Green LED's gpio direction to output
var ledGState = false; //Boolean to hold the state of Green Led
//instantiate red led
var myOnboardRLed = new mraa.Gpio(6); //Red LED hooked up to digital pin 6
myOnboardRLed.dir(mraa.DIR_OUT); //set Red LED's gpio direction to output
var ledRState = true; //Boolean to hold the state of Red Led
periodicGActivity(); //call the periodicGActivity function
periodicRActivity(); //call the periodicRActivity function
function periodicGActivity()
  gLed(); //call green led function
function periodicRActivity()
  rLed(); //call red led function
function gLed()
  myOnboardGLed.write(ledGState?1:0); //if ledGState is true then write a '1' (high) otherwise write a '0' (low)
  ledGState = !ledGState; //invert the ledGState
  setTimeout(periodicGActivity,1000); //call the indicated periodicGActivity function after 1 second (1000 milliseconds)
function rLed()
  myOnboardRLed.write(ledRState?1:0); //if ledRState is true then write a '1' (high) otherwise write a '0' (low)
  ledRState = !ledRState; //invert the ledRState
  setTimeout(periodicRActivity,1000); //call the periodicRActivity function after 1 second (1000 milliseconds)
Credits
MJ Guillet
MJ Guillet
1 project • 3 followers
maverick hackster
Comments
Add projectSign up / Login
