Dávid Széll
Published
IOTA-Enabled UFO Catcher
Rebuilding the game, so you can waste IOTA coins too.
IntermediateFull instructions provided4 hours775
Things used in this project
Hardware components
Toy Claw Machine
I bought mine at a local store, but it is similar to this one
×1
Raspberry Pi Zero Wireless
I used one for the game and one to serve power.
×2
Grove - Relay
Seeed Grove - Relay
×2
LED Panel Mount Indicator, Yellow Green
×1
Momentary switch
×1
Resistor 220 ohm
Resistor 220 ohm
×2
5V 2.5A Switching Power Supply
Digilent 5V 2.5A Switching Power Supply
×1
Raspbian
Raspberry Pi Raspbian
IOTA Tangle
IOTA Tangle
Soldering iron (generic)
Solder Wire, Lead Free
Story
Read more
Schematics
Raspberry controlled Power Switch
Finished schematics
Code
test.py
Python
Code for testing the completed hardware
import RPi.GPIO as GPIO
import time
statusPin = 22
buttonPin = 27
relayPin = 17
coins = 1
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(relayPin,GPIO.OUT)
GPIO.setup(statusPin,GPIO.OUT)
GPIO.setup(buttonPin,GPIO.IN,pull_up_down=GPIO.PUD_UP)
GPIO.output(statusPin,GPIO.LOW)
while True:
  if coins > 0:
    buttonState = GPIO.input(buttonPin)
    if buttonState == False:
      print "Game-start signal sent"
      GPIO.output(relayPin,GPIO.HIGH)
      time.sleep(1)
      GPIO.output(relayPin,GPIO.LOW)
      coins -= 1
  if coins > 0:
    GPIO.output(statusPin,GPIO.HIGH)
  else:
main.py
Python
Code for the UFO-Catcher
import time
import sys
import zmq
from iota import Iota
from iota import Transaction
from iota import TryteString
import json
import threading
context = zmq.Context()
socket = context.socket(zmq.SUB)
statusPin = 22
buttonPin = 27
relayPin = 17
coins = 0
def button_processor():
  global coins
  while True:
    if coins > 0:
        print "New balance: " + str(coins)
        time.sleep(1)
        coins -= 1
    if coins > 0:
    else:
def payment_processor():
    seed = 'SEED'
    address = 'SWITCH_ADDRESS'
    p_api = Iota('https://nodes.devnet.iota.org:443', seed)
    while True:
      tx = ProposedTransaction(
        address=Address(address),
        message=TryteString.from_unicode('Power Socket payment.'),
        tag=Tag('POWERSWITCHCOIN'),
        value=1
      time.sleep(60)
tx = api.prepare_transfer(transfers=[tx])
result = api.send_trytes(tx['trytes'], depth=3, min_weight_magnitude=9)
socket.setsockopt(zmq.SUBSCRIBE, b'tx')
socket.connect('tcp://zmq.devnet.iota.org:5556')
x = threading.Thread(target=button_processor)
x.start()
y = threading.Thread(target=payment_processor)
y.start()
while True:
  try:
    topic, data = socket.recv().decode().split(' ', 1)
    if topic == 'tx':
      tx_hash, address, value, obs_tag, ts, index, lastindex, bundle_hash, trunk_hash, branch_hash, received_ts, tag = data.split(' ')
      if address == "ADDRESS" and tag == "IOTACATCHERCOIN999999999999":
          coins += int(value)
          print "Payment received"
  except KeyboardInterrupt:
    print("Stopping now")
    x.join()
    y.join()
    sys.exit()
requirements.txt
BatchFile
Python requirements
PyOTA==2.0.7
pyzmq==18.0.1
powerswitch.py
Python
Code for power supply
import time
import sys
import pprint
import json
relayPin = 17
timeRemaining = 0
lastBalance = 0
seed = 'SEED'
while True:
   if timeRemaining > 0:
      timeRemaining -= 1
    else:
    x = api.get_account_data()
    balance = int(x["balance"])
    change = balance - lastBalance
    timeRemaining += change
    time.sleep(60)
Credits
Dávid Széll
Dávid Széll
1 project • 1 follower
Comments
Add projectSign up / Login
