mac28Michael AnginoYidi WangBrian HoepflNicholas Meisburger
Published
Mewzk Layzer
The highest quality sound in a small. lightweight package.
BeginnerShowcase (no instructions)508
Mewzk Layzer
Things used in this project
Hardware components
Grove - Ultrasonic Ranger
Seeed Grove - Ultrasonic Ranger
×1
Breadboard (generic)
×1
Jumper wires (generic)
×1
Buzzer
Buzzer
×3
Display Driver, LCD 4 Digits
×1
Grove Starter Kit for LaunchPad
Seeed Grove Starter Kit for LaunchPad
×1
EK-TM4C123GXL TM4C Tiva LaunchPad
Texas Instruments EK-TM4C123GXL TM4C Tiva LaunchPad
×1
Energia
Texas Instruments Energia
Breadboard, Plain
Breadboard, Plain
Tape Measure, Manual
Story
Read more
Schematics
The circuit board
Code
Music Laser Library
C/C++
#ifndef MUSICLASER_H_
#define MUSICLASER_H_
#include "Energia.h"
#include "Ultrasonic.h"
class MusicLaser {
private:
	 * Initializes the necessary information for buzzer to play notes, as well as preset tempo and note frequency.
	int buzzerPin;
	int tempo = 200;
	int tones[13] = { 1915, 1804, 1700, 1607, 1519, 1432, 1351, 1275, 1204, 1136, 1073, 1014, 956 };
	Ultrasonic ultrasonic;
public:
	int note = 13;
	MusicLaser(int buzzerPin, Ultrasonic ultrasonic): buzzerPin(buzzerPin), ultrasonic(ultrasonic){};
	void setUp ();
	void playTone (int tone, int duration);
	void playNote (int noteKey, int duration);
	int getDistance ();
	void loopFunc();
#endif /* MUSICLASER_H_ */
Music Laser Library cpp file
C/C++
#include "MusicLaser.h"
void MusicLaser::setUp() {
	 * Completes setup by initializing buzzer pins.
	pinMode(buzzerPin, OUTPUT);
void MusicLaser::playTone (int tone, int duration) {
	 * Plays note by turning on and off buzzer with durations corresponding to the frequency of the note.
	for (long i = 0; i < duration * 1000L; i += tone * 2) {
	    digitalWrite(buzzerPin, HIGH);
	    delayMicroseconds(tone);
	    digitalWrite(buzzerPin, LOW);
void MusicLaser::playNote(int noteKey, int duration){
	 * Calls play tone with a specfied note key as input that will access an item in the array.
	this->playTone(tones[noteKey], duration);
int MusicLaser::getDistance() {
	  * Takes distance from distance sensor and then determines the coresponding note bin.
	  * Returns the note bin.
	  float distance = ultrasonic.MeasureInCentimeters();
	  if(distance > 103){
	    distance = 103;
	  int noteKey = distance / 8;
	  this->note = noteKey + 1;
	  return noteKey;
void MusicLaser::loopFunc() {
	 * Call this function in the void loop section.
	 * Calls get distance to determine distance and then plays the note for the bin returned by getDistance.
	 * Calls playNote to play note.
	int noteKey = this->getDistance ();
	playNote (noteKey, this->tempo);
	delay (this->tempo);
Implementation of Library
C/C++
#include <MusicLaser.h>
#include "TM1637.h"
 * Defines constants for pins
#define ULTRASONIC_PIN 24
#define DIO 38
#define CLK 39
 * Initializes the 4 digit display
TM1637 tm1637(CLK, DIO);
int8_t bits[4] = {0};
 * Initializes instance of musicLaser
Ultrasonic ultrasonic(ULTRASONIC_PIN);
MusicLaser musicLaser(5, ultrasonic);
   * Calls setup method on musicLaser and sets up 4 digit display.
  musicLaser.setUp();
  tm1637.init();
  tm1637.set(BRIGHT_TYPICAL);
   * Calls musicLaser loop fundtion to play notes and displays note bin on 4 digit display.
  musicLaser.loopFunc();
  showDist ();
void showDist() {
   * Prints bin number to 4 digit display.
  int number_dist = musicLaser.note;
  memset(bits, 0, 4);
  for (int i = 3; i >= 2; i--){
    bits[i] = number_dist % 10;
    number_dist = number_dist / 10;
    tm1637.display(i, bits[i]);
Credits
mac28
mac28
1 project • 0 followers
Michael Angino
Michael Angino
2 projects • 0 followers
Yidi Wang
Yidi Wang
Brian Hoepfl
Brian Hoepfl
Nicholas Meisburger
Nicholas Meisburger
Comments
Add projectSign up / Login
