theresa_angl
Published © GPL3+
Indoor CO2 Sensor "kukO2"
The purpose of "kukO2“ is to detect the CO2 content in indoor areas.
IntermediateProtip461
Things used in this project
Hardware components
MQ135
×1
Arduino UNO & Genuino UNO
×1
Lichterkette mit 3V oder 5V
×1
SG90 Micro-servo motor
×1
Grove - Barometer (High-Accuracy)
Seeed Grove - Barometer (High-Accuracy)
×1
Laser cutter (generic)
Story
Read more
Custom parts and enclosures
the cutting mask for the house
Schematics
kukO2
This is how you need to assamble the parts.
Kuko2 steckplatine dpijw24hxc
Code
kukO2 Indoor air quality sensor
C/C++
The „kukO2“ has the purpose to detect the CO2 content in indoor areas.
It shows the level of CO2 when the concentration or cognitive abilities decrese.
// inlcude librqries needed:
#include <SoftwareSerial.h>
#include <Servo.h>
// Initiate Servo oject
Servo window_control;
// These constants won't change:
const int sensorPin = A0;    // pin that the sensor is attached to
const int LEDPIN = 9;        // pin that the LED is attached to
const int ZU = 10;            // Position of the servo motor for start (Zu)
const int AUF = 30;         // Position of the servo motor for end - position (a18uf)
const int BAD_AIR = 220;     // Default Wert empirisch ermittelt fr schlechte Luft
const int GOOD_AIR = 150;    // Default Wert empirisch ermittelt fr gute Luft
const int OPEN = 1;          // Define value for "OPEN" using the button
const int CLOSED = 0;        // Define value for "CLOSED" using the button
const int TASTE_IN = 7;      // define digital input channel to connect the button
// variables:
int window_pos = 0;          // Variable controlling the window position (open and closed)
float sensorValue = 0;       // the sensor value
float bad_air = BAD_AIR;     // Loaad limit value with default
float good_air = GOOD_AIR;   // Loaad limit value with default
int window_status = CLOSED;  // Variable storing window status (closed or open)
// Setup routine:
  // declare the Input nd output pins used on Arduino:
  pinMode(TASTE_IN, INPUT);  // sets the digital pin 7 as input
  pinMode(LEDPIN, OUTPUT);   // Set external LED control
  window_control.attach(10); // declare usage of PWM pin "10"
  Serial.begin(9600);        // initialize the debugging monitor for development purposes
  Window_close();            // Close window at start
  start_sensor();            // Sensor ein paar mal einlesen, bis er gute Werte erzeugt.
// endless main- loop:
  digitalWrite(LEDPIN, HIGH);         // Light control LED
  Read_CO2_Sensor();                  // Read in the CO2 senor value
  Calibrate();                        // Set a new current "good value" to calibrate the mechanism
  Serial.println(sensorValue);        // send sensor value to debugging window
  if(sensorValue < good_air)          // In case current sensor value is better as worst "good air" limit
    if(window_status != CLOSED)       // Check if window is not closed already
      Window_close();                 // close the window
      window_status = CLOSED;         // remember it was closed
  else if (sensorValue > bad_air)     // Check if current sensor value is worse as allowed bad air limit
    if(window_status != OPEN)         // Check if window is open already
      Window_open();                  // open the window
      window_status = OPEN;           // remember it was closed
  digitalWrite(LEDPIN, LOW);          // Reset control LED
// Supporting functions:
// Function Checking for settinng new "good air limit"
void Calibrate(void)
  int i;
  int taste;
  taste = digitalRead(TASTE_IN);
  //Serial.print(" Taste: ");       // for better redability in debug window
  //Serial.print(taste);            // send sensor value to debugging window
  Serial.print("      Limit: ");
  Serial.print(abs(good_air));      // send current good air - limit to debug window
  Serial.print(abs(bad_air));       // send current good air - limit to debug window
  Serial.print("      Act-Value: ");
  if(taste == 0)
    good_air = sensorValue;         // set the new good_air limit to the current value (after windos had been opened for a while)
    bad_air = good_air + 30;        // Set the jysteresis to 40PPM
    for(i=0;i<10;i++){              // Start control LED to blink showing new calibratin was made sucessfully
      delay(50);
      delay(50);
// Function to read in analog sensor signal for a while as
// first measurements are not accurate
void start_sensor(void)
  const int NUM_OF_READ = 1000;    // number of read cycles not used for "window" control
  int i=0;                        // because the sensor must get warmed up first.
  for(i=0;i<NUM_OF_READ;i++)      // for loop
    analogRead(sensorPin);        // read the sensor in
    delay(10);                    // delay by 10ms
// Function to read in analog sensor signal and make a "Mittelwert"
// This is because the sensor signal turned out to be very unstable
void Read_CO2_Sensor(void)
  const int NUM_OF_READ = 200;
  float new_value = 0.0;
  int i=0;
  for(i=0;i<NUM_OF_READ;i++)                // for loop reading in NUM_OF_READ sensor vlues and make average
  {                                         // as the sensor is not really stable
    new_value = analogRead(sensorPin);      // read the sensor in
    sensorValue = sensorValue + new_value;  // add to the last sum of sensor values
  sensorValue = sensorValue/NUM_OF_READ;    // devide by number of read ins
// Function closing the window by control of servo motor
void Window_close(void)
 for(window_pos = ZU; window_pos <= AUF; window_pos++)
      window_control.write(window_pos);
      delay(25);
  Serial.println(" - OPEN -");      // Show Closing status on debug window
  window_control.attach(11);        // declare usage of PWM pin to an unused pin "11" to eliminate permanent noise of motor
// Function opening the window by control of servo motor
void Window_open(void)
   tone(3, 70);                       // Make sound with the buzzer
   for(window_pos = AUF; window_pos >= ZU; window_pos--)
      delay(25);
  Serial.println(" - CLOSE -");       // Show Closing status on debug window
  noTone(3);                             // Stop sound
Credits
theresa_angl
theresa_angl
1 project • 0 followers
Comments
Add projectSign up / Login
