陈毅
Published © GPL3+
Time Trigger
A clock that only works when someone is in front of it. You are the only one who can trigger the clock to display the current time.
BeginnerFull instructions provided17 hours606
Time Trigger
Things used in this project
Hardware components
Seeeduino Lotus V1.1 - ATMega328 Board with Grove Interface
×1
Grove - Ultrasonic Ranger
Seeed Grove - Ultrasonic Ranger
×1
Grove - RTC
Seeed Grove - RTC
×1
Step Motor 42BYGH47-401A
×1
Stepper Motor Driver Board TB6560 TB6600
×3
Timing Belt (6mm x 400mm)
×3
Clear Transparent Frosted Acrylic (1m x 1m x 0.04m)
×1
White Acrylic (1m x 1m x 0. 2m)
×1
20-teeth Synchronous Wheel (internal diameter 5mm, length 6mm)
×3
60-teeth Synchronous Wheel (internal diameter 5mm, length 6mm)
×3
Screws, generic
×6
Nuts, generic
×3
3D-printed parts
×6
Black Matte Spray Paint
×1
MCU Adaptor (5V)
×1
Stepper Motor Driver Adaptor (36V)
×1
Glue
×1
Jumper wires (generic)
×1
Arduino IDE
Arduino IDE
Adobe Illustrator
3D Printer (generic)
Laser cutter (generic)
Story
Read more
Custom parts and enclosures
时钟装置
stepper motor
Code
TIme Trigger
Arduino
#include <DRV8825.h>
#include "Ultrasonic.h"
#include <FlexiTimer2.h>
#include <DS1307.h>
#define STEP1 8
#define STEP2 9
#define STEP3 10
#define DIR1 5
#define DIR2 6
#define DIR3 7
Ultrasonic ultrasonic1(2);
Ultrasonic ultrasonic2(3);
DS1307 clock;//define a object of DS1307 class
int pre_h = 0;
int pre_m = 0;
int pre_s = 0;
int delta_h = 0;
int delta_m = 0;
int delta_s = 0;
bool s_run = 0;
bool m_run = 0;
bool h_run = 0;
bool run_flag = 0;
void step(int n,int pin)
  for(int i=0;i<n;++i)
    digitalWrite(pin,HIGH);
    delayMicroseconds(200);
    digitalWrite(pin,LOW);
void test()
    step(320,STEP1);
    step(320,STEP2);
    step(320,STEP3);
void Clock()
  if(run_flag == 1)
    delta_s = clock.second - pre_s;
    delta_m = clock.minute - pre_m;
    delta_h = clock.hour - pre_h;
    if(delta_s<0) delta_s += 60;
    if(delta_m<0) delta_m += 60;
    if(delta_h<0) delta_h += 60;
    step(320*delta_s,STEP1);
    step(320*delta_m,STEP2);
    step(400*delta_h,STEP3);
    pre_h += delta_h;
    pre_m += delta_m;
    pre_s += delta_s;
    if(pre_h>=60) pre_h %= 60;
    if(pre_m>=60) pre_m %= 60;
    if(pre_s>=60) pre_s %= 60;
    delta_s = 0;
    delta_m = 0;
    delta_h = 0;
    run_flag = 0;
  pinMode(STEP1,OUTPUT);
  pinMode(STEP2,OUTPUT);
  pinMode(STEP3,OUTPUT);
  pinMode(DIR1,OUTPUT);
  pinMode(DIR2,OUTPUT);
  pinMode(DIR3,OUTPUT);
  digitalWrite(DIR1,HIGH);
  digitalWrite(DIR2,HIGH);
  digitalWrite(DIR3,LOW);
  pre_h = 0;
  pre_m = 0;
  pre_s = 0;
  run_flag = 1;
  clock.begin();
  clock.getTime();
  FlexiTimer2::set(10, 1.0/1000, Clock);
  FlexiTimer2::start();
  clock.getTime();
  ultrasonic1.MeasureInCentimeters();
  ultrasonic2.MeasureInCentimeters();
  if(ultrasonic1.RangeInCentimeters<=60||ultrasonic2.RangeInCentimeters<=60)
    run_flag = 1;
  }else
    run_flag = 0;
Credits
陈毅
陈毅
1 project • 1 follower
Comments
Add projectSign up / Login
