Vallabh deshpande
Published © GPL3+
Soil Moisture Monitoring with Bolt IoT
Using YL-69/HL-69 sensor with the Bolt Wi-Fi Module to read the moisture of soil and send an SMS alert crossing threshold value.
BeginnerFull instructions provided4 hours92
Things used in this project
Hardware components
Bolt WiFi Module
Bolt IoT Bolt WiFi Module
×1
Soil Moisture & Temperature Sensor
Seeed Soil Moisture & Temperature Sensor
×1
Jumper wires (generic)
×1
USB-A to Mini-USB Cable
×1
Bolt Cloud
Bolt IoT Bolt Cloud
Bolt IoT Android App
Story
Read more
Schematics
soil moisture schematic
Code
soil moisture monitering code
Python
import config    #this file contains the SSID API Key and Bolt device ID
import json,time,math,statistics    #used to call methods to fetch data...calculate Z cross....and give delays
from boltiot import Sms,Bolt     #used to call methods to sen SMS and use Bolt WiFi Module
def compute_bounds(history_data,frame_size,factor):       #This function was created to calculate the Mean,Variance and Z crosss
    if len(history_data)<frame_size:
        return None
    if len(history_data)>frame_size:
        del history_data[0:len(history_data)-frame_size]
    Mn=statistics.mean(history_data)
    Variance=0
    for data in history_data :
        Variance += math.pow((data-Mn),2)
    Zn = factor * math.sqrt(Variance / frame_size)
    High_bound = history_data[frame_size-1]+Zn
    Low_bound = history_data[frame_size-1]-Zn
    return [High_bound,Low_bound]        #This function returns a Upper Bound Threshold and Lower Bound Threshold
mybolt = Bolt(config.API_KEY, config.DEVICE_ID)        #To configure the Bolt WiFi Module
sms = Sms(config.SSID, config.AUTH_TOKEN, config.TO_NUMBER, config.FROM_NUMBER)       #To configure the Twilio SMS Service
history_data=[]           # This is a list to store the values recieved from the Sensor
while True:
    response = mybolt.analogRead('A0')     #Read the values
    data = json.loads(response)     #store the response given recieved in JSON format
    if data['success'] != 1:            # To detect if the value recieved contains keyword success and corresponding value should be 1 denoting STATUS OK
        print("There was an error while retriving the data.")
        print("This is the error:"+data['value'])
        time.sleep(10)
        continue
    print ("This is the value "+data['value'])  #To print the Analog Value received form the Bolt WiFi Module
    try:
        soil=(int(data['value'])/1024)*100   #To convert the vales in Percentage
	soil = 100-soil	     #To find the moisture content left in soil out of total 100%
        print ("The Moisture content is ",soil," % mg/L")
    except e:
        print("There was an error while parsing the response: ",e)
        continue
    bound = compute_bounds(history_data,config.FRAME_SIZE,config.MUL_FACTOR)
    if not bound:
        required_data_count=config.FRAME_SIZE-len(history_data)
        print("Not enough data to compute Z-score.Need",required_data_count,"more data points")
        history_data.append(soil)
        time.sleep(10)
        continue
    try:
        if soil < 30:
            print ("The Moisture level has decreased. Sending an SMS.")
            response = sms.send_sms("Please water the plants")
            print("This is the response ",response)
    except e:
        continue
    try:
        if soil > bound[0] :
            print ("The Moisture level increased suddenly. Sending an SMS.")
            response = sms.send_sms("Someone is damaging the plants")
        elif soil < bound[1]:
            print ("The Moisture level decreased suddenly. Sending an SMS.")
        print("HIGH BOUND = ",bound[0])
        print("LOW BOUND = ",bound[1])
    except Exception as e:
        print ("Error",e)
    time.sleep(10)
config.py
Python
SSID = 'xxxxxx'
AUTH_TOKEN = 'xxxxxx'
FROM_NUMBER = '+xxxxx'
TO_NUMBER = '+91xxxx'
API_KEY = 'xxxxxxx'
DEVICE_ID = 'xxxxxx'
FRAME_SIZE = 10
MUL_FACTOR = 3
Credits
Vallabh deshpande
Vallabh deshpande
1 project • 1 follower
Comments
Add projectSign up / Login
